Hi, Firstly you will not be able to control this drive from the computer's serial port without a dedicated controller with it's own software.
This drive has step and direction pins as most do nowadays and I suggest you get a breakout board which will have a connection for the parallel port (using a cable) and terminals for you to connect your drives.
You will then be able to control your project with software like Mach3 or similar CNC software.
Hope this helps. |
