Originally Posted by Helstrom Thanks for all your info ataxy!
Always a pleasure to hear from fellow Canadians. Merci beaucoup mon ami pour toutes les informations (sorry my written french is a little rusty). |
pas de probleme sa me fait plaisir!
Originally Posted by Helstrom Based on all the positive feedback on this style of Mill just helps reinforce my confidence in my purchase. Now if only CSA will approve it and then BusyBee can get them to the store.  |
weird why do they to get it approved since its allready sold in canada
Originally Posted by Helstrom When you received your mill was it shipped in a single container? What were thw boxes approx measurements, did you have it delivered or did you pick it up yourself? I'm just trying to plan out how I'm going to get it into my basement and whether I can do it myself.
Frank |
i got mine delivered, it was two box one that wasnt to bad +/-60pounds for the base cabinet and the mill wich was poorly crated so unless busybee recrate it you will get the same flimsy crate, 1/8" plywood for the wall and 1/2" plywood for the bottom on wich the mill is screwed, i got but the mill was still in perfect shape as for bringing it down stair, i have mine down stair, it was quite a job to bring down at around 250 pounds but whe were only two
