I'm now wondering if the factory servos on the 4400M are actually geared differently than the steppers on the older 4400C.
If I look at DC servos commonly available and in the same weight range as the AC units from Mitsubishi, they are around 600 and 1100 oz.in. respectively. Geared 5:1, they would be roughly the same power as the AC servos on the 4400M....
__________________ List of parts sources for CNC builders - http://www.CNCsources.net
Dyna Mechtronics 4400C Conversion - CNC bed mill w/toolchanger to Mach3 conversion - http://www.cnczone.com/forums/showthread.php?t=50787 |
