i have exactly the same mill but branded under the name elite from garant in levis quebec i must say that i am more then happy with it the only con that i think it as is the fact that its a mt2 taper wich is not as common as the regular r8 taper but the overall built of this mill is really good it offers excellent regidity and performance and with the option of been able to get a longer table it is more then a good candidate to be converted to cnc
here is the site of the company that makes them in china
http://www.weiss.com.cn/products/wmd20v.php
Originally Posted by Helstrom
There is also a quick question, when a mill states that it's "End mill capacity is 5/8" does that mean that 5/8" cutting dia is the largest size that the motor can handle or does it refer only to the maximum tool shank diameter? I ask because for certain design work I will need to use a 7/8" dia endmill and ball endmill. I'm sure there must be some reduced shank type endmills that will work with shallow cuts and lubrication on 6061 aluminum.
the motor can handle more i order this holder wich is er-32
http://cgi.ebay.ca/ER32-MT2-M10-COLL...QQcmdZViewItem
as for the morse taper i have ordered some collet true ebay for pretty cheap and the are well made for the type of performance and precision you can expect from such a machine
here is wherei bought mine
http://stores.ebay.ca/CTC-Tools
edit: i have check with busybee the one they sell does not seem to come with any equipment so you will have to buy accessorie seperatly
here is the one i bought
http://www.garantmachinerie.com/Indu...erie%20WSM.pdf
