Old 05-26-2003, 06:27 PM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
cycles initial plane/retract plane
I'm just wondering whether the general consensus on how Xp's initial plane and retract plane works for machine cycles is correct for your machine?
I make it work by forcing values into the cycle wizard that do not exactly match anything in the real world. What I see in the output code is that the initial plane is being subtracted from the clearance plane as though it were an incremental value, whereas I actually need them both to be absolute values.
Does it seem to be right from where you are working from?
Example: Initial plane input 0.4
Retract plane 0.2
Output in code is:
Retract plane is at Z.2 absolute, but initial plane is Z0.2 absolute.
