The folowing of the straight line sounds like you are picking the geometry at the wrong end. When you choose the geometry to cut, does your arrow go clock wise or counter clockwise? This determins which side of the geometry you will cut.
As for the stock size for the verify, it is set in "JOB SETUP" , available after clicking on "TOOLPATHS" in the main menu. Your "0" position is also set here, as well as whether or not to "show stock".
Hope this is not too confusing. |
