Old 01-19-2008, 11:28 PM
Smitty911 Smitty911 is offline
Smitty911 is on a distinguished road
Thanks for the tip
Originally Posted by MonroePoteet View Post
I have a Fog Buster that I use with my Taig. Worth every penny, IMO. Well built, easy to install, easy to use, no problems at all. And I didn't even get the "good guy" deal. I just use brown paper towels to sop up what minimal coolant builds up on the stock / table. None at all gets into the air, from what I can tell. I use KoolMist formula #78, which appears totally inert and harmless (stains a little if you let it dry, though).
My only complaint is they didn't have any good requirements for air supply, so I bought a compressor that was too small and had to upgrade. I now use an 8 gallon, 2HP, 4cfm@90psi oilless compressor from Harbor Freight, which is located about 40 feet away in a separate room for noise suppression and so it's on a separate circuit from the mill (prevents browning out the mill circuit and causing missed steps). Works great when I keep the supply pressure at about 35psi...above that and the FB oscillates when it first starts up. As I said, worth every penny, IMO.
One caveat: be sure to align the FB each time you change cutters. I broke about 3 of my 1/32nd cutters before I realized the FB was pointed too low. It appeared to be working (saw coolant flowing) but it was cooling / blowing on stock rather than the contact point. I now use an inspection mirror and sight up the FB's nozzle tube from below the cutter to make sure it's pointing at the cutter contact point.
mTp
I have my X-2 set up at work right now so I'll have shop air, if that 200 Gallon 120 PSI tank runs out of air, I won't be the only one screaming.
How bad do the chips blow around? You can see a picture of my mill in another post. Will I still be chasing chips all over, my side walls are about 10" high around 3 sides, I have the front, but have not put it on yet.
Sounds like I made a good decision, although more expensive. Kinda like the Geckos over some other stepper drives. LOL
I arrives Monday, can't wait.
Smitty
