Solutions for Lifting head | | The usual implement for lifting the milling head is that torsion spring arm arrangement, but that's not good enough for me. I want the same action as on a drill press. You know with the right stuff to lift it to where you started. What about two 50lb lift gas tubes mounted to the side of the mill head? Help, I really hate the present system. |
