Old 07-05-2004, 04:13 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Al,
I would have to con cure with metlmunchr about G41 being modal with most controls, until canceled. So the duplicate G41 would not be necessary.
That being the case, your moves between circles would be comp-ed also. This may be the weird moves you are seeing as the control comps the rapid moves instead of the normal "straight line" rapids your are used to.
I also noticed that you have not called out a diameter number for the control (IE: D1 for tool #1). Not knowing your control's likes and dislikes, this may not matter.
Line N140 to N190 appear to be cutting air as they are at clearance height. (z.10) Again maybe this is how you intended it to be.
Also line N170 you have called out a G41 without any x/y move. This may not be accepted by some controls. As they need an x/y move on the same line as the G41/G42 call out. And some only accept a G01 or G00 move and not a G03/G02 move with the G41/G42.
Just some ideas as I don't know what controller you are using.
