Wow, this is what I mean by spectacular stuff. I love the receptionist desk area. (It's things like this that got me into carpentry years ago)
So you use the CNC machine to mill out large pieces of crown? How is the surface after you mill it out? Does it require a little sanding to remove any residue ridges? Normally, if I need a large cove, I just mill it out on the tablesaw by passing the lumber above the spinning blade at a skewed angle. It works great but requires a lot of sanding to remove the saw marks.
I'd love to see this done with a CNC router. I imagine that not only can you mill out the large cove but also add design elements!!!
Here is how I do it... for the moment!
