I work in a commercial cabinet shop programming a large CNC router and CNC saw. Here is a picture of the type of work we do. When I get to back to work I'll see if I can find a pictue of the framework of this round soffit on the ceiling. If I recall it's about 20ft diameter. I'll try to find a bigger picture, too.
I'm building (If I can ever find the time) a router to use in the stuff I build at home. I plan on using it a lot for 3D carving.
I made a piece of MDF cove moulding on our work machine for my fireplace mantel. I also routed a mating piece to use for a caul for veneering it. By wetting the veneer slightly, I was able to make about 1/8" radius bends. I'll take a picture in a second of a small cutoff.
__________________ Gerry
