Old 07-03-2004, 05:35 PM
Al_The_Man's Avatar
Al_The_Man Al_The_Man is offline
In the past I have used 12dp rack 20deg pressure angle 1inch face , this has a slightly higher higher load capacity than the 14.5 pressure angle. The final counts per unit of movement depends on the # of teeth of the spur gear and the gear/belt reduction used so I would not worry about tailoring the rack so it works out to anything even etc as most software allows the entry of any fractional ratio counts per unit of movement.
Al
