You will at some time overstoke it, so depending on the concequences this maybe a bad idea.
The time you most need a safety device is when you are least experienced. Should you fit learning stabilisers to your childs bicycle before or after they have an accident. Don't answer that.
Phil
Originally Posted by BrassBuilder Ed,
I'll go back and wire the limit switches later.
Mike |
