The hi/low speed work with the hydraulic cylinder pressing down on the belt with a idler wheel that will activate the other range. The range that is not working will have slack on the belt...magically the non working range belt will not be rubbing. You can test for motor mount issues by taking your hand and pressing back or pulling forward on the motor with the cable tensioner loose. This will tell the story (For future reference). |
