Old 01-13-2008, 09:13 AM
drwc drwc is offline
drwc is on a distinguished road
Sounds like you need to adjust your gibb strips with the adjustment screws along the side of the slide. You should be able to tighten these up till you can't wiggle the slide, I had to tighten them carefully to remove play, you will need to take time and care to get the adjustment as good as possible. If you can't get rid of play then you will need to look at refinishing the dovetail or the gibb strips (or both ) to allow a satisfactory adjustment.
Good Luck
Wayne
