My 1st post – so bear with me.
Has anyone tried installing a Stepper Motor to the Z-axis fine wheel feed using the same method as blades did with his Y-axis and the timing belt?
I know this would not be the best way but would be a cheap way and you could simply use the stock mechanism to engage and disengage for manual use.
Also the low power motor should turn Z-axis fine wheel feed – I think. |
