Thread: TM1 faults
Old 01-10-2008, 04:54 PM
Geof Geof is online now
Check all the cable connectors for the Y axis and spindle to make sure they are tight; things can rattle loose.
Also check for a sticking limit switch on the Y axis; this can give the zero return margin error if it is gummed up and moves slowly.
