Originally Posted by MASTERCAMMASTER Of course I AND J codes are better with cad cams, but R'S are easyer to program manually.
The guy is a novice why don't you give him something to use forever not a computer generated program.
P.S. You have 10 lines at the top of the program you can delete, lol
I BET YOU LEARNED CAD CAM THEN STARTED WORKING AT A MACHINE SHOP. |
use "I" and "J" when the end points are more important
use "R" or "P" when the radius is more important
the faster your feed rate the less accurate the machine will be so you need to tell it what's important
