Old 07-01-2004, 04:13 PM
ESjaavik ESjaavik is offline
*Registered*
ESjaavik is on a distinguished road
Originally posted by dcd121
Here is a related question. I have some 5/8" dia ball screws for all axis that travel 20 mm per turn. I plan on using a servo setup with them. I know I will have enough power and speed but would someone like to speak about the accuracy issue?
Thank you
If connected directly to the servo it will be lower than one with 5mm/turn. But if you gear down 1:4 and do it without backlash in the gear (planetary or cyclic) , it will be the same. Your moment of inertia will be lower because you have geared down. So your motor will be able to accelerate it quicker. That's a pro.
But a gear without backlash is expensive and bulky. That's against. Unless you get a ballscrew integrated with a gearbox it's also more components to make to adapt the gear to the machine and the motor to the gear.
