Parameter 257 is your spindle oretation offset. After you put it back togother you should be able to oreintate the spindle and adjust the parameter as needed to line up with the tool changer. I also had a wierd noise it was my spindle drive on a VF-6. Can you turn the spindle freely when the machine is on and the spindle is at a stand still? |
