Old 01-08-2008, 11:22 AM
bob1112 bob1112 is offline
bob1112 is on a distinguished road
Remove drive belt on 96 VF-1 w/ TSC/ reset spindle orient
We have some odd noise uptop and want to remove the belt to isolate the noise. Talked with Haas but not much help with the TSC stuff. In order to slide the motor/trans assy forward enough to get the belt off, we need to remove that tool clamping block thing in front of the trans. We have TSC and curious what we need to do here??The trans is loose but have not tried to remove the tool clamping block.
Obviously, once the belt is off, we need to reset the spindle orient for the TC. How is that done? Our 96 has the old shot pin thing so probably some manual setup here. Thanks
