Vcarvz is a text layout and 3D V-cutter carving program. It incises Tru-type text outlines, and will also alternate between incised and relieved contours within a flat DXF contour file. This software tool was originally designed as a supplement to VectorCad-Cam. It is still optimized for use with Vector, but can now also be used with any CNC G-code controller. No intervening Cam programming step is required.
The code is generic and has been tested to work directly within DeskCNC. The DeskCNC editor can simulate the actual V-carving as a rendered 3D surface, running the complete program or single/multiple block stepping.
Sample DeskCNC cut file simulation image here:
http://www.imsrv.com/6x3ovalVcarvz.jpg
The upgrade is free to all previous Vcarvz customers. A 30 day demo is available for download at
Fred Smith - IMService
