The dxf-> GCode in Mach1 is the same as Master5. You select import... and then load the dxf file. You set parameters such as "as drawn" to keep coordinates the same as the DXF, or don't select it to set the coordinate base to 0,0,0.
Select the depth of the z when cutting and select the feedrate during a cut.
Then select import. In Mach1, the system wil immediately ask for a G-Code file name for the new G-Code, it will then load the file after conversion.
__________________ www.gearotic.com
Art Fenerty |
