Chuy,
like Crazy thunder said it is easy to set one offset, but you may have to set the plane wcs not fixture for each pocket to machine each pocket toolplane from the one G54 offset. Unless the toolplanes for each pocket are the same angle then you will only have to set the toolplane once per side.
Steve
www.cad2cam.net
