Thanks to all, for your previous responses.
I now have the cutter moving across the part while I line feed down the code.
Simulation as you all describe sounds like what I would want to use. Correct me if I'm wrong, but I believe you all have the XP-Expert version. Do you know if there is any less of a simulation feature in XP-Professional than in XP-Expert?
Also any explanation of any other differences would be appreciated.
All I've heard so far is that XP-Expert is more suited than XP-Professional, for splitting mold work.
Also is it correct that XP-Expert is about $3000.00 more than XP-Professional?
Does either version program 4th axis from a solid without having to lay it out in a flat view? |
