Thanks Dcoupar, now, unfortunately, for my next question: ATC sequence problem on this OSP700M Cadet Mate. Doing a manual tool return with no next tool, the ATC comes into position to accept the tool, the spindle unclamps the tool, and then the spindle refuses to retract to the (HP2) out of the way position so that the ATC can retract. Anyone have any solutions for a problem like this? I've completely powered down the machine hoping I could clear some underlying fault but that didn't help. I've unclamped the tool and manually put it in the ATC and then tried to call up a different ntool but it won't forget the tool that it had in the spindle. I've even tried to run the program in place with the tool in question but the program just blinks on the auto screen and nothing happens even though that is the tool that is needed in the program. There's a system reset button in the main panel enclosure, will this reset the system without any ill effects? Thanks for any help you guys can give. Marty |
