I haven't tried it yet, but would there be an speed advantage to running parallel on this motor for reduced inductance, even if I can only run 2A out of 3A spec'ed? |
There would be no difference in inductance between running bipolar half coil and bipolar parallel. The only advantage of parallel over half coil is that it allows you to use higher current. This gives more low speed torque but won't make a difference in torque at high speeds.
PS According to the spec sheet it is 2.4mH not 4.8
