Old 01-02-2008, 02:32 PM
Geof Geof is offline
It is not a parameter,there is a little adjustment screw/knob on the side of the monitor. You may be able to find a plastic plug blocking the access hole on one side or the other or you may need to take the back cover off to get at it.
