Old 01-02-2008, 01:40 PM
ZipSnipe ZipSnipe is offline
ZipSnipe is on a distinguished road
Uumm upon further inspection of the gcode I found something weird. When I designed this design(MastercamX) all I did was make a curvy L shape and then xform mirror(which copies a mirror image opposite) and then a second xform mirror which should have created 4 L exactly the same size and depth. But when I checked the gcode I noticed the 3rd L is several thou shallower and about .050 off on its return path(it makes 2 passes on each L shape). Thats one part of the weird, the second part is when I check the home position the x is out! This led me to believe it was missing steps. Here,s the code http://www.cnczone.com/forums/attach...1&d=1199302874
Todd and Angie.txt Look at line #114 ,318 and 726. Compare that with line#522(3rd L)
Any ideas?
