Old 01-01-2008, 04:41 AM
saacengineering saacengineering is offline
saacengineering is on a distinguished road
ATC
the way i solved my problem was by resetting the ATC data table in NC/PC mode. It tends to get corrupt every so often, my sub programs worked fine but the problem was in my data table it gets corrupeted if u dont have ur memory protect on or press ATC button after the inital start up. if you need the data table i have it, you can try to reset it see if that works, on my machine i have to reset the pramaters every month or so.
