call an electrian there are ways around this problems moving up breaker sizes will void your warenty and can cause problems that are expencive to fix. if somthing gose wrong dew to power isusse. you may also be voiding you house insurance depending on the area you live in and the bylaws.
to save 500- 1000 bucks could cost you 10 times that. ask the electrian about a fused switch panel run of the break panel easy fix not to expencive if you can do it
just my 2 cents |
