Very cool... I was wondering if you could use a print head from an HP color printer. Something like that.. Just an idea... I dont think an injector will work as the one I have seen have more then one hole in them.. Also most injectors on have 14 lb of fuel pressure on them.. There in a regulator that takes the 70-120 lb of fuel down.. the high pressure is so that there will always be more fuel then needed. That’s why there is a return line to the gas tank. |
