Old 12-26-2007, 04:46 PM
dewme5 dewme5 is offline
dewme5 is on a distinguished road
working with solids
I'm almost ashamed to ask. I've created a solid in PartModeler 11.5, and then brought it into edge cam. Go thru the normal stuff to start laying out the milling operations. For the first operation, I want to center drill. When I choose the hole operation, there are no points that I can select. I can choose rough, and everything is selectable, but under hole, nothing is.
When creating, I created a rectangle, extruded it, then placed a circle on top, and cut thru all. Now, I have a square solid with 1 hole completely thru it. Save, close, open in edgecam 11.5 and I can't drill it?? i've never run into this before. What am I doing wrong?
