Mortek, that sounds like a lot of extra work. It is far quicker to draw in solid (if applicable, and is a simple entity) and get many surfaces all done at once. You can always extract a curve from the edges where you need to make an adjustment.
In XP, btw, you can extract all the curves in one go, should you want. But this usually makes a clutter I don't really need, so I just extract what I need in the local area of concern and work on it.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
