i got this file attached to work
i had to make everything i was using in the verify mode a continious solid.
i just copied my solids 2 a diffrent layer, then did a boolean add.
then goto the stock tab and select solid, then select your solid.
i did have to keep the solid i made for the verify visible, or it would dissapeer
when i clicked on the verify button
im assuming this is still gonna work adding parts and more toolpaths |
