Old 12-24-2007, 10:49 AM
Mastercam User Mastercam User is offline
*Registered*
Mastercam User is on a distinguished road
Steve, if you turn off True Solid it is faster but what good is that because you can't rotate or zoom the model and you can't save the STL file! How do I know if we have multi-axis Verify? We supposedly have the "full boat" package of Mastercam. Level 3 mill. The computer has 2 gigs of ram. We had a trial of CG Tech Vericut. Vericut worked great on our computer. Backplot works fine but there are times we need to see a solid being cut. When I try and solid Verify the STL file with True Solid it bombs out or stops cutting the STL file
I've tried changing the settings to less quality and more speed but it doesn't help. Any suggestions so I can at least save the finished True Solids STL file?
