Are you using Mach 2 as your controller? If so when I first setup the new version on my router my servo system did the same thing. The code would run for about 20 to 45 seconds and then with a very fast shake, one drive or two would fault.
I had to play with the speed and acceleration in Mach 2 before it would stay running smoothly.
I did not have this problem with an older version of Mach 2. When I upgraded to the new release I had all my setting the same. Art must have made some changes that made the system more sensitive.
__________________ Thanks
Jeff Davis (HomeCNC)
http://www.homecnc.info
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
