What about a simple copy mill? Place your workpiece on a long base board with a template on one side or both sides set below the cutters lowest point, fit cam follers near to the cutter head and just feed your work through, the cutter head will smoothly feed up & down following the templates, then use twinned-drive down feed screws to adjust the depth of each pass. Sounds such a simple profile why bother with CNC |
