Originally Posted by Smackre Do you think there would be a issue with condensation. I cant get water in the oil. And if condensation gets into the oil it pretty much ruins it. |
as long as the evaporator is completely under the oil, and you have insulated lines running to and from the tank, it should be good... however then you have oil leeching/wicking back up whatever insulation you have on it.
