Old 12-17-2007, 08:49 PM
kprice1658 kprice1658 is offline
kprice1658 is on a distinguished road
That sounds good if it were a single part being turned over.
I will actually be using 2 different mold blanks (4"x6"). Lets call them top & bottom. I'll setup the bottom and cut as normal. On the top blank - if I cut it the same, it needs to flipped ( say the x axis) it it comes down on the bottom blank in the exact same position - so the alignment holes and more importantly - the cavities of the molds line up perfectly.
Whew - this is hard to explain...
Kevin
