SP,
Can't agree with you more. I think Scott did an outstanding job on this, I use it all the time to verify my programs.
Dave
Originally Posted by single phase I vote for the FANUC lathe double line G75 command set. It would be great to see this work as well as it does for the G90 and G94 commands.
Even without the G7X commands there is nothing out there that does this as well as NCPLOT! If you are setting on the fence about this application, go ahead and pull the trigger, you will be amazed at how much faster and accurately you can write g-code for you lathe.
With NCPLOT you can write code that is much faster and more to-the-point than code from any CAM tool out there.
Cheers
SF |
