Hi Marc,
So you know you can redefine the acc/dec ramps whenever you need to, right? That is to say, you're not permanently stuck with the settings that you made in the setup page. Although I haven't played with any handwheel logic yet, I can imagine that there would be a special balance to be achieved, if you don't use decelstop in the handwheel logic. I'm not saying that you'd want to use it except when you exit handwheel mode, but in the same vein, more conservative (or more aggressive) acc/dec settings might be required (with or without DECELSTOP) whle in handwheel mode, just to prevent drive faults. In a servo system, you might get drive faults, in a stepper system without feedback, I suppose you'd just lose steps.
__________________ First you get good, then you get fast. Then grouchiness sets in.
