No i dont use P4 for the moment , its easier and faster to use
P32 and you also have more power for grinding complex profiles
i think you have a limitation in P4 that the steptool only can get bigger in diameter and that limits me , the dxf loading is a nice thing since all drawings comes in dwg or dxf files , so its just to cut out you profile from the drawing and load it into P32 and your
almost done.
on the other hand in P4 you can gash the inside rake angle on the differnt steps so you dont get negative rake angle on the smaller steps in diameter, but there is for sure more nice things in P4 that i dont know about .
if you have any problems just tell me , and i would do the same.
// Jake |
