Steve,
Is there any way you can clamp the part to the V block, and never remove it until you are finished? I'm imagining that you would have more success by relying on the squareness of the ends of the V block, rather than the part.
Assuming that the part is longer than the V block, you could increase the height of your V block with a 1-2-3 block spacer between the V block and the chuck.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
