Old 12-06-2007, 02:44 PM
Rekd's Avatar
Rekd Rekd is offline
Rekd is on a distinguished road
You got about as far as I've gone. I haven't tried to do any toolpathing with VBS yet, so I can't help you. Sorry.
This may be of some help, though. Good luck!
Code:
'//        Author:   Mick George Mick.George@Mastercam.com
'//          Date:   28/10/2003 03:28 PM
'//     File Name:   Toolpath Door CHook.vbs*
'//   Description:   Run Door CHook, create <style> door, set level 1 INSIDE and level 2 OUTSIDE
'//                  then create one door, exit chook. Create your operations and save them to
'//                  DOOR.OP9 And run this script
'//      Comments:   You don't need to create a door, this script can apply to any drawing that has
'//                  two inside pocket operation and an outside contour.
'///////////////// My Constants /////////////////
' -- Operations library
Const DEF_OPERATIONS_LIB = "DOOR.OP9"
' -- Operation comments for each operation saved
Const DEF_OP_INSIDE_ROUGH_POCKET = "INSIDE ROUGH POCKET"
Const DEF_OP_INSIDE_FINISH_CONTOUR = "INSIDE FINISH CONTOUR"
Const DEF_OP_OUTSIDE_CONTOUR = "OUTSIDE CONTOUR"
' -- Level numbers
Const DEF_INSIDE_LEVEL = 2
Const DEF_OUTSIDE_LEVEL = 1
' -- Start Script
Call Main()
' Sub Declaration
Sub Main()
Dim strPathToOP9, ovOverRides
If Not IsDrawing Then ShowString "We need a drawing!": Exit Sub
strPathToOP9 = GetPathFromExtension("OP9")
strPathToOP9  = AddBackSlash(strPathToOP9) & DEF_OPERATIONS_LIB
' -- If you want to over-ride the operations depth now is the time...
Set ovOverRides = New McOverride
With ovOverRides
.DepthOn = True ' -- Override operation depth?
.Depth  = -.125 ' -- New depth If DepthOn = True
.FeedRatePercentOn = True ' -- New feed rate Is a percentage?
.FeedRate = 80
.SpindleSpeedPercentOn = True ' -- New spindle speed Is a percentage?
.SpindleSpeed= 80 ' -- New spindle speed If SpindleSpeedOn = True
End With
Call GetReady
' * Chain all entities on our inside level
If ChainAll(True, False, DEF_INSIDE_LEVEL, vbNullString ) Then
   ' -- Apply our rough pocketing routine
   If MakeOperationFromName(strPathToOP9,DEF_OP_INSIDE_ROUGH_POCKET,DEF_OP_INSIDE_ROUGH_POCKET, ovOverRides) <> mcOPERATION_INVALID Then
       ' -- Apply our finish pass
       If MakeOperationFromName(strPathToOP9,DEF_OP_INSIDE_FINISH_CONTOUR,DEF_OP_INSIDE_FINISH_CONTOUR, ovOverRides) <> mcOPERATION_INVALID Then
          ' -- Ok to go
          Call GetReady
       Else
          ShowString "Could not apply " &  DEF_OP_INSIDE_FINISH_CONTOUR & " operation"
          Call GetReady
       End If
   Else
      ShowString "Could not apply " &  DEF_OP_INSIDE_ROUGH_POCKET & " operation"
      Call GetReady
      Exit Sub
   End If
    ' * Chain all entities on our outside level
    If ChainAll(True, False, DEF_OUTSIDE_LEVEL, vbNullString) Then
       ' -- Apply our outside contour routine
       If MakeOperationFromName(strPathToOP9,DEF_OP_OUTSIDE_CONTOUR,DEF_OP_OUTSIDE_CONTOUR, ovOverRides) <> mcOPERATION_INVALID Then
           ' -- Clear all
           Call GetReady
       Else
          ShowString "Could not apply " &  DEF_OP_OUTSIDE_CONTOUR & " operation"
          Call GetReady
          Exit Sub
       End If
    Else
       ShowString "Could not chain outside level"
    End If
Else
   ShowString "Could not chain inside level"
End If
End Sub
' Function Declaration
Function IsDrawing()
Dim Ret
Ret = StartDBSearch(mc_alive, -1)
IsDrawing = Ret
End Function
' Sub Declaration
Public Sub GetReady
Call FreeChains
Call UnselectAll
Call RepaintScreen(True)
End Sub
Function AddBackSlash(sPath)
If Right(sPath, 1) <> "" Then sPath = sPath & ""
AddBackSlash = sPath
End Function
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
