Hello Cabnet, I see you got your start with the carvewright machine, Small world I got started with that as well, and agree with your post about the software over on the CW forum. They made the simple things so easy in Designer.To do the same Simple things in other programs takes much longer to do. Over at LHR plans were to develop a pro version that would out put g-code or even easier have it output in STL format ,almost all cad/cam packages let you import a STL
Thanks,
Ben |
