Originally Posted by xyzdonna ...I think hydrogen could, however, replace natural gas in the home for clean and relatively efficient heating. Think about it, no heat exchanger required. Just have a fan blowing across the flame and ducting the combustion products into the home. It would provide the benefit of adding humidity to the home since the product of combustion would be water vapor.... |
For your information the product of natural gas combustion is mostly water with a bit of CO2; natural gas is CH4. You can burn it safely inside using a catalytic heater and you get far too much moisture inside with resulting mould problems where the moisture condenses on cooler walls.
But anyway using hydrogen in place of natural gas is not sensible: As I mentioned much earlier there are currently in use two sources for hydrogen; natural gas and electricity. Either of these can be used for home heating with better overall efficiency.
Many of the ideas, suggestions, etc to combat global warming are no more sensible and no more logical than this.
P.S. Dig up a chemist friend that you trust, maybe also a physicist; both of whom have no vested interest in making money from global warming or conning you into investing in their wonderful ideas. And ask them about the energetics of generating hydrogen. You display the same attitude of many people do who do not have a good education or understanding in science and technology. They believe the people who tell them the message they want to hear and do not believe the ones who, correctly, say it will not work.
