Old 12-04-2007, 06:14 AM
ozzie34231 ozzie34231 is offline
ozzie34231 is on a distinguished road
CAMLOCK, need some info, advise, ideas
Hi All,
I just acquired a 14 X 40 Taiwan lathe with D1-4 Camlock.
It's still crammed in my van while I make a bench for it and figure out how to get it out of the van.
I'm hoping I'll love this Camlock feature, but I don't know a lot about it and need some info.
How good is the repeatability of the system? For the sake of example, if I true a workpiece in a four jaw to nearly perfect, and I remove the chuck, and later replace it, how close will will the piece still be to perfect?
I think I'd like to make some additional chucks, a 5-c collet closer and a ER holder, and maybe an R-8 holder. The sense in making these is lost if the repeatability of the system is not within a tenth or two.
I've looked at some drawings of the system and it looks like the chuck plate rests on a taper and a flat. Is that true, or does it only rest on the taper?
The spec for the taper is given in degrees, minutes, and seconds! That seems strange, is there a reason for this odd angle?
If the target of the design is for both the flat and taper to engage perfectly, that presents a bit of a machining problem for making a new chuck. Does anyone have any ideas for a procedure? The only thing that comes to mind is to make a gauge that is a duplicate of the lathe spindle end, and slowly increase the diameter of the female taper until the gauge flat barely touches the workpiece flat. ???
Ozzie
