Old 12-03-2007, 09:35 AM
Geof Geof is offline
Originally Posted by Donkey Hotey View Post
.... 1" stock won't fit through a 5C collet. I might be able to bore a clearance through a collet and get away with it but it'll be snug......
Yes 1" will fit through a 5C; my tube processing adaptation on the TL does 7/8" and 1" tube. And I have seen 1-1/16" 5C collets.
.... So you have an enclosed TL-1? How do you like the enclosure? I have a friend who is going to order a TL and I'm trying to convince him that the enclosure is a good idea. He doesn't want it in the way of his knees when he's working over the machine.....
In the way of his knees??? How does he figure that? I have no difficulty and I have more or less normal length arms .
I would not be without the enclosure. It is not perfect and depending on how you direct the coolant nozzles it is possible to get a lot of leakage. I have installed some extra shields in different locations and have eliminated most of the problems. But I still put some plastic trays under the machine to catch the few drips that come down.
