Old 11-29-2007, 07:28 AM
rodzilla rodzilla is offline
rodzilla is on a distinguished road
Forgot
I forgot to mention what i am using as a power supply currently it is a LAMBDA SWS600-48 and when i take voltage measurements from the supply going into the geckos i get 60.1 volts. But when i hook my ground on multimeter to chasis and take measurement of the coil windings i get 30 volt. I am also using a 270K OHM resistor on the current set of the g202 when i measure resistance of the resistor not hooked up i get a reading of 265,000 OHMS, but when the machine is running i get 165,000 OHMS or i get OL
